  v0.9.3.9
teszt
Oldal 1 / 4
1  2   3   4     Következő ►  Utolsó ►|
MoparMan | 2056    2018-01-14 22:11:41 [182]
kepfeltoltes.eu
MoparMan | 2056    2018-01-14 22:11:09 [181]
kepfeltoltes.eu
MoparMan | 2056    2018-01-14 22:03:37 [180]
kepfeltoltes.eu
MoparMan | 2056    2018-01-14 22:03:11 [179]
kepfeltoltes.eu
MoparMan | 2056    2017-09-14 23:41:18 [178]
MoparMan | 2056    2017-09-14 21:44:51 [177]
http://foo.com/blah_blah http://foo.com/blah_blah/ (Something like http://foo.com/blah_blah) http://foo.com/blah_blah_(wikipedia) (Something like http://foo.com/blah_blah_(wikipedia)) http://foo.com/blah_blah. http://foo.com/blah_blah/. <http://foo.com/blah_blah> <http://foo.com/blah_blah/> http://foo.com/blah_blah, http://www.example.com/wpstyle/?p=364. http://userid:password@example.com:8080 http://userid@example.com http://userid@example.com:8080 http://userid:password@example.com http://example.com:8080 http://example.com/anything.html http://example.com/anything.php Just a www.example.com link. http://www.example.com/wpstyle/?p=364 teszt url
MoparMan | 2056    2017-09-13 21:54:42 [176]
[@1194]
MoparMan | 2056    2017-09-13 21:20:42 [175]
[code] const int SmartHomeAxisFld = 20602; bool HomeAxis(int AxisNo) { string WorkAxis = "XYZABC".Substring(AxisNo, 1); bool G28Move = Convert.ToBoolean(exec.Readkey("SmartHome", "G28Move" + WorkAxis, "false"); double G28Goto = Convert.ToDouble(exec.Readkey("SmartHome", "G28Goto" + WorkAxis, "0.0"); double CurrentPos = 0.0; bool SoftLimit = exec.GetLED(67); if (G28Move) AS3.Additemtolistbeginning("Homing " + WorkAxis + " with move to " + G28Goto, 2); else AS3.Additemtolistbeginning("Homing " + WorkAxis, 2); while (exec.IsMoving()){} if(exec.Ismacrostopped()) return false; [/code]
MoparMan | 2056    2017-09-13 21:16:55 [174]
[code] // ================================================================================================ // SmartHome v1.2 // ================================================================================================ string Axes = "XYZABC"; int Axis = 0; if (Qvar == null) { Axis = Convert.ToInt32(AS3.Getfielddouble(SmartHomeAxisFld)); if (Axis == 6) { for (int i = 0; i <= 5; i++) { Axis = Axes.IndexOf(AS3.Getcomboboxselection(4 + i)); if (Axis != -1) exec.Setaxishomestate(Axis, false); } for (int i = 0; i <= 5; i++) { Axis = Axes.IndexOf(AS3.Getcomboboxselection(4 + i)); if (Axis != -1) if (!HomeAxis(Axis)) return; } } else { exec.Setaxishomestate(Axis, false); HomeAxis(Axis); } return; } int Qint = Convert.ToInt32(Qvar); if ((Qint < 0) || (Qint > 5)) { AS3.Additemtolistbeginning("* M20928: Invalid Q", 2); return; } HomeAxis(Qint); // ================================================================================================ #Events const int SmartHomeAxisFld = 20602; bool HomeAxis(int AxisNo) { string WorkAxis = "XYZABC".Substring(AxisNo, 1); bool G28Move = Convert.ToBoolean(exec.Readkey("SmartHome", "G28Move" + WorkAxis, "false"); double G28Goto = Convert.ToDouble(exec.Readkey("SmartHome", "G28Goto" + WorkAxis, "0.0"); double CurrentPos = 0.0; bool SoftLimit = exec.GetLED(67); if (G28Move) AS3.Additemtolistbeginning("Homing " + WorkAxis + " with move to " + G28Goto, 2); else AS3.Additemtolistbeginning("Homing " + WorkAxis, 2); while (exec.IsMoving()){} if(exec.Ismacrostopped()) return false; switch (AxisNo) { case 0: CurrentPos = exec.GetXpos(); break; case 1: CurrentPos = exec.GetYpos(); break; case 2: CurrentPos = exec.GetZpos(); break; case 3: CurrentPos = exec.GetApos(); break; case 4: CurrentPos = exec.GetBpos(); break; case 5: CurrentPos = exec.GetCpos(); break; } exec.Code("G28.1 " + WorkAxis + CurrentPos); while (exec.IsMoving()){} if(exec.Ismacrostopped()) return false; if (G28Move) { if (SoftLimit) { exec.Callbutton(519); while (exec.IsMoving()){} } exec.Code("G0 G53 " + WorkAxis + G28Goto); while (exec.IsMoving()){} if(exec.Ismacrostopped()) { if (SoftLimit) { exec.Callbutton(518); while (exec.IsMoving()){} } return false; } if (SoftLimit) { exec.Callbutton(518); while (exec.IsMoving()){} } } return true; } // ================================================================================================ [/code]
MoparMan | 2056    2017-09-12 20:16:10 [173]
[code] #include <EEPROM.h> #include "EEPROMAnything.h" #include <SoftwareSerial.h> #include <TinyGPS.h> #include <Wire.h> #include <OzOLED.h> //#include <SD.h> //#include <Fat16.h> #include <FileLogger.h> #include "display_data.h" [/code]
MoparMan | 2056    2017-09-12 20:14:27 [172]
MoparMan | 2056    2017-09-12 19:58:19 [171]
test
MoparMan | 2056    2017-09-12 19:41:39 [170]
[code] char reply[100]; int i = 0; while (BTserial.available()) { reply = BTserial.read(); i += 1; } //end the string reply = '\0'; Serial.print(reply); Serial.println("Reply end"); } void loop() { [/code]
MoparMan | 2056    2017-09-08 21:13:49 [169]
[code] és [/code]
MoparMan | 2056    2017-09-08 21:12:55 [168]
&#x5B;code&#x5D; és &#x5B;/code&#x5D;
MoparMan | 2056    2017-09-05 22:38:29 [167]
[code] Set objWord = CreateObject("Word.Application" Wscript.Echo "Version: " & objWord.Version Wscript.Echo "Build: " & objWord.Build Wscript.Echo "Product Code: " & _ objWord.ProductCode() objWord.Quit [/code]
MoparMan | 2056    2017-09-05 22:34:06 [166]
[code] import unittest def median(pool): copy = sorted(pool) size = len(copy) if size % 2 == 1: return copy[(size - 1) / 2] else: return (copy[size/2 - 1] + copy[size/2]) / 2 class TestMedian(unittest.TestCase): def testMedian(self): self.failUnlessEqual(median([2, 9, 9, 7, 9, 2, 4, 5, 8]), 7) if __name__ == '__main__': unittest.main() [/code]
MoparMan | 2056    2017-09-05 22:13:32 [165]
[code] --- M20103.txt --- exec.Code(&quot;M20100 Q3&quot; while(exec.IsMoving()){} --- M20100.txt --- int Qint = 0; double ax = exec.GetXpos(); double ay = exec.GetYpos(); double az = exec.GetZpos(); double aa = exec.GetApos(); double ab = exec.GetBpos(); double ac = exec.GetCpos(); string ujsor = &quot;&quot;; string megj = AS3.Getfield(21000).Trim(); // Megjegyzes mezo szama a kepernyon if (Qvar != null) Qint = Convert.ToInt32(Qvar); switch (Qint) { case 0: case 3: if (mode == 1) { if (ax != px) ujsor = ujsor + &quot; X&quot; + ax.ToString(); if (ay != py) ujsor = ujsor + &quot; Y&quot; + ay.ToString(); if (az != pz) ujsor = ujsor + &quot; Z&quot; + az.ToString(); if (aa != pa) ujsor = ujsor + &quot; A&quot; + aa.ToString(); if (ab != pb) ujsor = ujsor + &quot; B&quot; + ab.ToString(); if (ac != pc) ujsor = ujsor + &quot; C&quot; + ac.ToString(); if (ujsor != &quot;&quot ujsor = &quot;G01&quot; + ujsor; if ((Qint == 3) &amp;&amp; (megj != &quot;&quot) { megj = megj.Replace(&quot;(&quot;, &quot;[&quot; // Nem lehet zarojel a megjegyzesben! megj = megj.Replace(&quot&quot;, &quot;]&quot; if (ujsor == &quot;&quot ujsor = &quot;(&quot; + megj + &quot&quot;; else ujsor = ujsor + &quot; (&quot; + megj + &quot&quot;; } if (ujsor != &quot;&quot System.IO.File.AppendAllText(SaveTo, ujsor + &quot;
&quot; px = ax; py = ay; pz = az; pa = aa; pb = ab; pc = ac; } break; case 1: SaveTo = AS3.Getfield(2017); System.IO.File.WriteAllText(SaveTo, &quot;G00 X&quot; + ax.ToString() + &quot; Y&quot; + ay.ToString() + &quot; Z&quot; + az.ToString() + &quot; A&quot; + aa.ToString() + &quot; B&quot; + ab.ToString() + &quot; C&quot; + ac.ToString() + &quot;
&quot; px = ax; py = ay; pz = az; pa = aa; pb = ab; pc = ac; mode = 1; break; case 2: mode = 0; break; } #Events static int mode = 0; static double px = 0.0; static double py = 0.0; static double pz = 0.0; static double pa = 0.0; static double pb = 0.0; static double pc = 0.0; static string SaveTo = &quot;&quot;; [/code]
MoparMan | 2056    2017-09-05 22:03:58 [164]
[code] O1000 T1 M6 G0 G90 G40 G21 G17 G94 G80 G54 X-75 Y-25 S500 M3 G43 Z100 H1 Z5 G1 Z-20 F100 X-50 M8 Y0 X0 Y50 X50 Y0 X0 Y-50 X-50 Y0 Y25 X-75 G0 Z100 M30 [/code]
MoparMan | 2056    2017-06-13 17:15:34 [163]
<font color="red">ez?</font>
MoparMan | 2056    2017-06-13 16:24:24 [162]
Gegegdh eheh & urjjd ruud < >
MoparMan | 2056    2017-06-13 16:19:50 [161]
x < 40
MoparMan | 2056    2017-04-09 23:49:40 [160]
http://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf[/pdf] ]TEXT LINK
MoparMan | 2056    2017-04-09 23:49:25 [159]
[pdf]http://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf[/pdf]
MoparMan | 2056    2017-04-09 23:38:50 [158]
[pdf]http://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftp.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftps.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftp://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftps://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftps://ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf[/pdf]
MoparMan | 2056    2017-04-09 23:36:52 [157]
[pdf]http://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf TEXT LINK http://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf TEXT LINK 2 www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftp.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftps.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftp://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftps://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf ftps://ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf TXT LINK ftps://www.ware-tech.com/kr/_library/document/servo/samsung/CSD3%20Servo%20User%20Manual_en.pdf[/pdf]
MoparMan | 2056    2017-04-09 23:36:32 [156]
MoparMan | 2056    2017-04-09 23:33:59 [155]
MoparMan | 2056    2017-04-09 23:33:00 [154]
MoparMan | 2056    2017-04-09 23:24:33 [153]
[pdf]$&[/pdf] [/url]
MoparMan | 2056    2017-04-05 21:58:01 [152]
Uraim! köszönöm a tesztet. Sikerrel zártunk.
MoparMan | 2056    2017-04-05 21:49:36 [151]
volt még egy hiba mit el kellett hárítani ha pl már megvolt a 10 klikk, de pl valakinél még úgy állt az oldal hogy mondjuk 9-et mutatott, akkor ugye ő tudott rá nyomni és akkor 11 lett. az a nyomorult meg úgy volt megírva, hogy ha a számláló nagyobb-egyenlő tíz, akkor elvett egyet a postjaid számából és hozzáadott egyet a töröltekhez így ha a fenti bekövetkezett akkor +2 és mínusz kettő, azaz helytelen a post számlálód állása szóval ez is kijavítva. ha fenti eset fennáll és klikkelnek, azt már nem fogja számolni, mer előtte vizsgálom meg az aktuális állást
Előzmény: PSoft, 2017-04-05 21:39:38 [148]
jani300 | 6516    2017-04-05 21:45:07 [150]
De látjuk ! Még Ki a bátor Egyébként nemrég láttam a gyermekemet veblappal dolgozni , keres egy hibát ...
Danibá60 | 4314    2017-04-05 21:42:16 [149]
Így nem beszélünk, töröljük.
Előzmény: MoparMan, 2017-04-05 21:36:43 [147]
PSoft | 10661    2017-04-05 21:39:38 [148]
Most, megint törölhető vagy! Nyomjak?
MoparMan | 2056    2017-04-05 21:36:43 [147]
jó, akkor csináld úgy mint délelőtt. egyrészt a kód azon részén semmi sem változott, másrészt kurvára mindegy mert úgy sem lesz mit látni. faszommá
Előzmény: szf, 2017-04-05 21:28:03 [145]
MoparMan | 2056    2017-04-05 21:35:40 [146]
kurva zárójel-erdő egy ")" hiányzott
Előzmény: svager, 2017-04-05 21:27:38 [143]
szf | 1637    2017-04-05 21:28:03 [145]
Délelőtt megmutatta!
Előzmény: MoparMan, 2017-04-05 21:27:15 [142]
Sz.József | 2824    2017-04-05 21:27:47 [144]
Igen, a pirosra gondoltam..., Ok... A 24 órás limit az biztos, hogy elégséges? Csak arra gondoltam, van aki 2-3 naponta olvassa a fórumot...
Előzmény: MoparMan, 2017-04-05 21:24:07 [139]
svager | 1139    2017-04-05 21:27:38 [143]
Már megint nem lehet törölni.
MoparMan | 2056    2017-04-05 21:27:15 [142]
mert androidon nem tudsz olyat csinálni hogy "ráhúzod az egérmutatót"
Előzmény: szf, 2017-04-05 21:24:44 [140]
szf | 1637    2017-04-05 21:25:27 [141]
Akkor nem érdekes a beíràsom
szf | 1637    2017-04-05 21:24:44 [140]
Laptopon kiírja kik törölték,androidon nem. Ha esetleg van jelentősége.
MoparMan | 2056    2017-04-05 21:24:07 [139]
ha a piros kijelzésre gondolsz, akkor nem, nem lesz látható
Előzmény: Sz.József, 2017-04-05 21:21:00 [138]
Sz.József | 2824    2017-04-05 21:21:00 [138]
Rosszul kérdeztem... A törlések száma (hogy hol tart) meg fog maradni?
Előzmény: MoparMan, 2017-04-05 21:19:09 [137]
MoparMan | 2056    2017-04-05 21:19:09 [137]
a sorszámozás fix, a törölt postok hiányoznak a sorból
Előzmény: Sz.József, 2017-04-05 21:18:34 [135]
PSoft | 10661    2017-04-05 21:18:50 [136]
Mindent...tesztelni kell!
Előzmény: Devecz Miklós, 2017-04-05 21:16:36 [134]
Sz.József | 2824    2017-04-05 21:18:34 [135]
A sorszámozás az meg fog maradni?
Előzmény: MoparMan, 2017-04-05 21:12:27 [130]
Devecz Miklós | 1966    2017-04-05 21:16:36 [134]
Kiengedted a szellemet a palackból. (#127)
Előzmény: MoparMan, 2017-04-05 21:12:49 [131]
PSoft | 10661    2017-04-05 21:15:02 [133]
Most, nyomjatok erre törlést! (én már, megtettem)
Oldal 1 / 4
